15 years agoNIOS is generating Read Signal Twice.
Hi, There is a custom interface of NIOS with a device, having own DSP-Processor. Interface is 16-bit data bus. While reading the data NIOS is generating CSn and RD Enable twice. Please hel...
15 years agoSo, Nios 2 has a 32 bit read/write port (one for read and one for write) while your device has an interface with 16 bits on the avalon bus. This is a mismatch, the interconnect fabric in SOPC builder will split the read or the write in two. Take a look at http://www.altera.com/literature/manual/mnl_avalon_spec.pdf, paragraph 3.6.1
--- Quote Start --- For example, when a 32-bit master port performs a read transfer from a 16-bit slave port, the system interconnect fabric executes two read transfers on the slave side on consecutive addresses, and presents 32-bits of slave data back to the master port --- Quote End --- If I understood correctly your situation, this may be a good cause for reading twice.
