9 years agoNIOS II (system time problem)
Good evening,
I have an issue to get my "local" system time in nios 2 c/c++. At first I thought it could be easily implemented by using <time.h> library and its provided functions. I used localtime() as well as gmtime() to compare some results, but everything I could get were somehow constants. This is an example of my testing code //************* time_t t=time(NULL); struct tm ts; localtime_r(&t,&ts); unsigned char secs=ts.tm_sec; // secs has a range from 0..61 ....dont know why tm_sec is integer type when 6 bits are fully sufficient unsigned char min = ts.tm_min; // minutes unsigned char hour = ts.tm_hour; unsigned char day = ts.tm_mday; // and so on unsigned char month = ts.tm_mon; unsigned char year = ts.tm_year; // Actual date from 1900 ....meaning 2016-1900 should be =116 ...8 bits are enough in this case //*********************************** When I watch that values with printf() I am getting the same constants which dont fit at all. Same constants are shown when I use localtime()-,gmtime_r()- and gmtime()-function. Seconds are 0x3B // seconds and minutes are always the same ...by the way wrong Minutes are 0x3B // Hour is 0x17 // wrong Day is 0x1F // its the 31.12.16 ?? ... wrong Month is 0xB // Has a range from 0 to 11 ...meaning 11 represents decembre.. result is OK Year is 0x45 // decimal 69 ..... MS Visual Studio showed 116 (2016-1900) ..wrong I mean I ve used same functions in microsoft visual studio to make some comparisons.MS VS is actually showing me the right results which I am expecting but the NIOS processor is doing some unknown stuff. I ve made some research in the internet with " getting system time altera " and i think someone has sayed that the NIOS processor isnt able to use these mentioned functions properly. But how u re supposed to use this library correctly? I ve seen and read some different approachs like using ntp. But what can I do if I am only limited to a de0 nano development kit which has no ethernet protocol and so on for some testing. I think I ve read somewhere that u can communicate with the jtag uart and forcing it to send u the correct time and date. I ve seen some altera s tutorials how to send data to the jtag uart. But how am i supposed to force the jtag uart to send me the rigth time and date frame?No RepliesBe the first to reply
