15 years agoNIOS II problem with internal connection
Hi everyone, I have make a NIOS II based program for EP3C25 based board. In the block design entry NIOS II Block is connected with many Input/ output port like LEDs and switches. Also another ...
15 years agoYes you can do that. Are you sure the trigger signal is changed as you want? You can use signaltap to check it.
