15 years agoNios II problem in programming
Hi, I want to load a program in the Nios II processor of cyclonII by ByteBlasterMV programmer. I encountered with an error that it means:I can not use a ByteBlaster programmer and I should use a U...
15 years agohi,
version of my quartus II and my Nios II is 7.2. yes, it is a warning and it appeared as follows: warning: the JTAG cable you are using is not supported for Nios II systems. you may experience intermittent JTAG communication failures with this cable. please use USB revision B cable or another supported cable. please refer to the file errata.txt include in the Nios II dvelopment kit documents directory fopr more information. connected to hardware target using JTAG UART on cable '' ByteBlasterMV [LPT1]'' , device 1, instance 0 (USE the IDE stop button or Ctrl-C to terminate) after this warning did not occure any thing. In a document of the altera website, I studied that for programming of Nios II, we should use USB-Blaster programmer. now, how to use my ByteBlaster programmer? Best Regards,
