15 years agoNios II not accessing custom external SRAM
I created an SRAM_512x16 component in SOPC builder using the New Component tool. I instantiated it in SOPC Builder and connected it to the system through an Avalon-MM Tristate Bridge to the Nios II ...
13 years agoOpen the tcl file for the custom external SRAM and make sure ismemorydevice is set to true
set_interface_property avalon_tristate_slave ismemorydevice true In the component editor tab labeled interface, there should be a check box in the deprecated section (on newer SOPC version) that allows specification of the component as a memory device.
