15 years ago
Nios II IDE program to test SGDMA and DMA
Hi all,
I include here Nios II IDE program to test SGDMA and DMA, if in case someone is needed.
Just rename .doc to .c
Have a good weekend.
Sean
    caridee: This is not like test memory. It's only for DMA and SGDMA.
    DMA: Connect through Avalon-MM (memory map)
    SGDMA: Connect through Avalon-ST (streaming)
    You have to connect it to SDRAM and test from there.
    It's kinds of Avalon-MM and Avalon-ST.
    Sean
    Thanks sean! So, does it similar to the memory test which used to test those off-chip memories like sdram, flash and .etc?
    Caridee
Recent Discussions
