13 years agoNios II flash programmer error
Hello all, I'm trying to generate the flash program to my device [de2-115], I'm generating the web server demo and using Nios II IDE (NOT Eclipse). However, I'm getting the error says on 80% of th...
13 years agoEven if it were a TSE license problem, the CPU would still answer.
Did you configure the FPGA with the .sof file you compiled with Quartus? Are there any timing fails reported by Timequest? Do you have the same problem if you use the .sof file from the standard nios project provided with the kit, instead of compiling your own?
