13 years agoNios II flash programmer error
Hello all, I'm trying to generate the flash program to my device [de2-115], I'm generating the web server demo and using Nios II IDE (NOT Eclipse). However, I'm getting the error says on 80% of th...
13 years agoThe CPU not working can come from several factors, such as an Opencore evaluation expiring (if you don't have the license for the Nios II core) or a problem in your design, such as a bad clock, a stuck reset signal, or a design not meeting the timing requirements. Are you using the stock DE2-115 quartus project, or your own?
