14 years agoNIOS II Flash Programmer - System ID not found
Hello Everyone, I am trying to program the FPGA using the NIOS II Flash Programmer. Im getting errors whenever I try to open the settings.bsp or .sopcinfo files...it says: -Connected sy...
14 years agoHi,
you did not use the System ID peripheral component in your system. This will result in an error in the flash programmer when the system id check is activated. In your case it looks like the system id check is disabled. This results in a warning. You should be able to program the flash. Regards, HJS
