11 years agoNios II EPCS booting problem
Hi, I am using DE0 nano and trying to boot Nios II from EPCS configuration device. I am following the procedure mentioned on this link (http://www.alterawiki.com/wiki/epcs_bootloaders). Th...
9 years ago --- Quote Start --- Hi Danish.I meet the same problem.can you tell why should we do the step 9 and 10.thanks. --- Quote End --- --- Quote Start --- These steps create a memory initialization file / boot loader to be used by EPCS controller during boot process. --- Quote End --- Thank you.I will have a try. http://www.alteraforum.com/forum/showthread.php?t=49409&highlight=mem_init_generate In the link. mellis mentiond " The FAE discovered that the NIOS II/e will not boot from the serial flash controller (Quartus 15.0) and the work-around is to use the NIOS II/f instead". Is that right?
