11 years agoNios II EPCS booting problem
Hi, I am using DE0 nano and trying to boot Nios II from EPCS configuration device. I am following the procedure mentioned on this link (http://www.alterawiki.com/wiki/epcs_bootloaders). Th...
11 years agoWhen you run "mem_init_generate" from eclipse, a folder named mem_init will be created under software/your_eclipse_project_name/. There you can fine *.qip file which you need to add in your Quartus project along with verilog/VHDL files.
