10 years agoNios BSP Editor Linker Region Allocation for .text
I have a Nios with a 2KBytes on-chip memory and its firmware image(.hex) store at external flash. What is the difference between if I assign the .text linker section to "on-chip memory" and assigned it to "External Flash" ? Which approach is much more better? Do I need to do some firmware handling in the NIOS if assigning .text to "External Flash"? As I know that code will be executed more faster if in on-chip memory compare to external flash but it'll consume the memory block in the FPGA, am I understanding correctly? Thanks advance in helping!!^^No RepliesBe the first to reply
