18 years agonewbie asks about "LATCH primitive ... is permanently disabled"
Folks, I have a DE1 (CycloneII starter board) to learn VHDL and Quartus. I developed and successfully tested my bit-shifting FIFO UART on the DE1. With this design functional, I'd like to move it ...
18 years agoA latch primitive is an asynchronous latch inferred from your code, something like
if a='1' then
c <= b;
end if;
Disabled means, the condition a='1' does never occur in your code. Quartus is issuing a warning, cause it suspects, this behaviour may be unintentional. The warning is similar to a dead code warning from a C-compiler line xxx is never executed. If you expect the condition to come true sometimes, you should check the code why it actually doesn't.
