15 years agoNewbie - direction prod needed
Hi, Firstly, please excuse my lack of knowledge in this area... I have been playing around with some CPLD's and FPGA's and have done some basic logic designs which work well. Now i...
15 years ago --- Quote Start --- Nios2 isnt needed but it's recommended You probably need a DMA to transfer the data Cyclone is the low-cost FPGA and it should fufill your needs --- Quote End --- Many thanks Cyclone starter kit on the way! Could you explain why the Nios2 isnt needed but recommended? would it just be a lot simpler to achieve my goal goind down thew Nios core route? So i have setup a A Uart SPI_Slave_To_Avalon_Master onchip_memory onchip_fifo and DMA So i guess a little code in the Nios core to check if anything is in the fifo, if there is, then move it to the SPI memory mapped area or Use the Nios2 to setup the DMA to automatically move that data? Does anyone know of any examples i could study for this? Many thanks Billy
