14 years agonetlist conversion from Xilinx to altera compatible
Hi, I am working on porting netlists from Xilinx ISE to Altera Quartus III. Can anyone help me in fixing this issue? Is there a converter or any software to convert Xilinx compatible netlist t...
14 years ago --- Quote Start --- I am working on porting netlists from Xilinx ISE to Altera Quartus III. Can anyone help me in fixing this issue? Is there a converter or any software to convert Xilinx compatible netlist to Altera compatible one?? --- Quote End --- What do you mean by a netlist? What you should really have is the original source code in Verilog or VHDL format. You would then change the Xilinx IP for equivalent Altera IP and then resynthesize. Cheers, Dave
