15 years agoNegative spykes on all internal signals in EP4CE15E22C7N
Hello. I use the EP4CE15E22C7N device. (E144 package). The only clock connected is 50MHz, 3.3V to one of the clk inputs. The VCCIO connected to clean 3.3VDC, the VCCINT and VCCPLL to clean 1.2...
15 years agoWhen i take to SignalTap a counter w/negative logic Sync Reset input and feed it with a constant '1' (created using the noprune attribute) i can see that when SignalTap shows negative spike, in some cases the counter resets, so it looks like the spike is real...
