15 years agoNeed Help with FFT code
Hi, I am trying to implement a FFT code on the altera DE1 board. I have some doubts regarding the procedure. 1.Can i simulate the outputs of the FFT in Quartus 11??If so,Can you provide ...
15 years agoYou need to create text file in Matlab for your input and one for your ref outputs then let the testbench read them. You may already have testbench generated by your tool (ip core) then all you might need is point to those files.
