15 years agoNeed Help with FFT code
Hi, I am trying to implement a FFT code on the altera DE1 board. I have some doubts regarding the procedure. 1.Can i simulate the outputs of the FFT in Quartus 11??If so,Can you provide ...
15 years agoIn any dsp module testing is same, you get stimulus input then its reference output from a software tool e.g. Matlab then pass same input to your module and check outputs for errors. You need a testbench to read stimulus file and ref file then compare.
For fft use Matlab fft, just one statement: y = fft(x,64); however you need care to get frame boundaries (64 data frame) correct between Matlab and module. You also need match scaling issue and fft centre(dc centred or not)
