15 years agoNeed Help with FFT code
Hi, I am trying to implement a FFT code on the altera DE1 board. I have some doubts regarding the procedure. 1.Can i simulate the outputs of the FFT in Quartus 11??If so,Can you provide ...
15 years agoLike nplttr (http://www.alteraforum.com/forum/member.php?u=31357) said
The simulation model is created by the FFT generator, in case of VHDL, you should use the vho file for simulation and the vhd for synthesis.
