RGonz26
7 years agoNeed assitance on MPN 5SGSMD5H3F35I3LNAA, different failure modes observed in our production floor at jabil guad.
Need assitance on MPN 5SGSMD5H3F35I3LNAA, different failure modes observed in our production flor at jabil guad. See attached FAs
Zawani_M_Intel
7 years agoUpdate the answer on behalf of Jabil's Team ;
1. Functional Failure, FA shared for more details.
2. Different dates, since the end of the last year. In our test, values out of range was read.
3. We see the error at the test, after that, we retest in order to double check the error at the test. After we remove the device and replace it with a new one in order to validate if the failure follows the device. After that we put the “bad device” in a golden board to double check the failure.
4. No.
5. No, we run under parameters. Profile parameters and Moisture sensitivity handling guides could be shared by mail if be required.
6. Yes, the failure follows the device.
