13 years agoNCO with Cyclone V
Hi all, is there anyone who knows when the IP NCO will be a final version for Cyclone V ? Thank you, Jean
13 years ago --- Quote Start --- I chose Multiply-Based instead of Cordic, large ROM or small ROM. it should use the DSP blocks (As indicated resource Estimate)! For a test, I created another project (naturally with the same cyclone V and I only use the same NCO) and he uses DSP Blocks! It's weird !!! :) --- Quote End --- I am a bit lost. Are you aware that dsp block means mult in altera language? So if you ask for mults you get dsp blocks in resource.
