13 years agoNCO with Cyclone V
Hi all, is there anyone who knows when the IP NCO will be a final version for Cyclone V ? Thank you, Jean
13 years ago --- Quote Start --- I set ( Use Dedicated Multiplier(s) ) in the parameterize menu (Implementation) and the Resource Estimation said: 2 DSP Blocks, 2 M10Ks 12288 Memory Bits 1977 LEs ??? --- Quote End --- So it is ok then. You can also set architecture of nco as (I think): large memory, or small memory, cordic...etc. The full memory or cordic doesn't need any multipliers, the small memory requries few mults possibly two as in your case. These mults are used to interpolate new values from the small memory samples.
