13 years agoNCO Sine output
HI All, I am trying to generate sine output from NCO with in the range of 1Mhz to 21Mhz , Altera Megacore function NCO has an input called frequency modulation incremenet "freq_mod_i [F-1:0]" h...
13 years agoThat input is used exactly for the same purpose as it is mentioned in documentation: MODULATION. You don't need that if I understood you correctly.
