18 years agoNCO megacore function problem
Hi i have a problem using the megacore function NCO . I made a model in which i have a NCO which generates a sine. i want this sine to be put out to the D2A_converter1 to display it on a oscill...
18 years agoIn the StratixII EP2S180 board, there is a jumper to select the clock resource for the DAC device. You can select the oscilator, the PLL output clock, and the external clock resouse. I think it is using the PLL output clock in your jumper setting. And this tcl file can make the pin assignment on that location.
