töz00
6 years agoMULTI-CORE NIOS II SYSTEM CAN RUN AT THE SAME TIME?
hi every one, I have a code which calculates 9 sinus but this calculation lasts about 30 ms . so i decided to divide this calculation to three parts and run in 3 nios processors so that i can do thi...
Isaac_V_Intel
Contributor
6 years agoHello Taha,
Yes, you can run multiple Nios processors at the same time, every Nios is independent. You can follow the next link [1] with some information about how to create multiprocessors. Also, you can refer to the section "The dining Philosopher's problem"
Let me know if it works and if you have more questions about it.
[1] https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_nios2_multiprocessor_tutorial.pdf
Isaac.
töz00
6 years agoThank you for your support! I solved my problem. They are running almost without any time loss.
