10 years agomsel in multiple configuration schemes
Hello, In my design with cyclone IV E, I have to use two configuration scheme options, AS and FPP, the problem is that the data sheet says the MSEL pins which define the configuration scheme sh...
9 years ago --- Quote Start --- Thanks alot both of you! --- Quote End --- FYI, The Cyclone V databook has been updated to read: Section 7-2: MSEL Pin Settings To select a configuration scheme, hardwire the MSEL pins to VCCPGM or GND without pull-up or pull-down resistors. Note: Altera recommends connecting the MSEL pins directly to VCCPGM or GND. Driving the MSEL pins from a microprocessor or another controlling device may not guarantee the VIL or VIH of the MSEL pins. The VIL or VIH of the MSEL pins must be maintained throughout configuration stages. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
