10 years agomsel in multiple configuration schemes
Hello, In my design with cyclone IV E, I have to use two configuration scheme options, AS and FPP, the problem is that the data sheet says the MSEL pins which define the configuration scheme sh...
10 years agoI've successfully driven MSEL pins, on Cyclone IV, from a micro. Indeed we have a shipping product that does just that. This followed previous work doing the same thing on a proprietary Cyclone II development platform. Make sure you have control over nCONFIG too so that you can ensure the MSEL sttings are stable when nCONFIG is released - when the MSEL pins are sampled. Don't try and use fast POR - there's no point.
There is one large caveat with this - it's not supported. As you pointed out, the datasheet states they should be tied directly to GND of VCCA and specifically states "do not drive the msel pins with a microprocessor or another device". As Galfonz points out, jumpers/dip switches achieve this, the micro doesn't. Altera are unlikely to support you should not comply with the datasheet. However, with our shipping product we took the decision - following extensive testing that showed no failures - that the risk was low. 5 years and a large number of units later we have not seen any issues. My fingers remain crossed... Cheers, Alex
