15 years agoMove data from NIOS to hardware and then back to NIOS
I am trying to do a little calculation in hardware but I'm stuck on how to get started. I'm a complete newbie, but after reading a lot of manuals and demos, I figured out that I could have a soft pro...
15 years agoFor loops are synthesizable but may give different results that what you expect. In this case it would create 8 multipliers and 8 adders that would all work in parallel to do the operation in one clock cycle. If you want to have only one multiplier and do the operation in 8 cycles instead, then yes you need to get rid of the loop and do a clocked process.
