10 years agoMonitoring Output from Cyclone IVGX
Hi I have a CycloneIVGX board (Onboard a Terasic De2i-150) and the problem I have encountered seems a very novice (nonetheless). I have a simple counter module that is continuously generating output ...
10 years ago --- Quote Start --- Hi I have a CycloneIVGX board (Onboard a Terasic De2i-150) and the problem I have encountered seems a very novice (nonetheless). I have a simple counter module that is continuously generating output (32 bit values that is). I wanted some form to observe the output physically so I thought of the following Do you use SignalTap II? This is part of the software that comes with Quartus II it builds a logic analyzer inside the FPGA that you are building. It outputs a chart very much like a logic analyzer. https://www.youtube.com/watch?v=vhkzxcexuaa Or if you really want to see the signal with external software but don't really need to see all 32 bits you could try this low cost product: https://www.saleae.com/ Best of luck. Kevin Kibbe
