15 years agoModelsim test vector to verify DDC/DUC working?
Hi there, I'm looking for Modelsim version in verilog test vector to verify my DDC/DUC working good or not. By using signal generator as input and look at signalTap to see the result. But no...
15 years agofirst create some stimulus (using MATLAB, Octave, etc) and save it to a .txt file. then read the text file in your test bench and feed it into your system
you can see an example by creating a filter with FIR Compiler and taking a look at the generated test bench
