8 years ago
Modelsim existing with 211
Am using Altera Ethernet 1588 TOD synchronizer in my project, when I am trying to simulate 1588 TOD synchronizer its causing "Modelsim error exiting with error 211"
without any error logs
Any one suggest me how to simulate Altera Ethernet 1588 TOD synchronizer in modelsim I also tried with default parameter settings.
Gayathri
    msim_setup is for complete qsys system/soc which is generated by a tool.
    I have used a default setting itself.
    Can you share the project file(.qar)?
    Anand Raj Shankar
    Hi Anand
    Thanks a lot for your reply now I can able to simulate, but in my project am also using pll TOD clk ip, How to generate a unique msim_setup.tcl.
    In TOD clk my period clk is 125MHz, below look at below config of TOD clk IP
    PERIOD_CLOCK_FREQUENCY => 0,
    OFFSET_JITTER_WANDER_EN => 1,
    DEFAULT_NSEC_PERIOD => 8,
    DEFAULT_FNSEC_PERIOD => 0,
    DEFAULT_NSEC_ADJPERIOD => 8,
    DEFAULT_FNSEC_ADJPERIOD => 0
    am not getting output, what value should I give in DEFAULT_NSEC_PERIOD ,DEFAULT_FNSEC_PERIOD ,DEFAULT_NSEC_ADJPERIOD and DEFAULT_FNSEC_ADJPERIOD
    Pls do the needful
    Gayathri
    Hi Gayathri,
    Modelsim transcript has been attached for simulation follow the steps in it.
    For more information check the script generated and follow the steps given msim_setup.tcl file OR refer previous threads in the forum and link below.
    https://www.altera.com/en_us/pdfs/literature/ug/ug_gs_msa_qii.pdf
    https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-5v3.pdf
    Anand Raj Shankar
