10 years agoModelsim error with PLL if parameters for dynamic features is enabled
Quartus 16 patch 16.0.2.2.2.2
Modelsim 10.5d I've got error if checked Altera PLL -> Settings -> Enable access to dynamic phase shift portsor any other dynamic parameter The error is# Reading D:/Altera/Prime_16/modelsim_ase/tcl/vsim/pref.tcl# do test_header_run_msim_gate_verilog.do# if {} {# vdel -lib gate_work -all# }# vlib gate_work# vmap work gate_work# Model Technology ModelSim ALTERA vmap 10.4d Lib Mapping Utility 2015.12 Dec 30 2015# vmap work gate_work# Copying D:/Altera/Prime_16/modelsim_ase/win32aloem/../modelsim.ini to modelsim.ini# Modifying modelsim.ini## vlog -vlog01compat -work work +incdir+. {test_header.vo}# Model Technology ModelSim ALTERA vlog 10.4d Compiler 2015.12 Dec 30 2015# Start time: 10:30:12 on Sep 26,2016# vlog -reportprogress 300 -vlog01compat -work work "+incdir+." test_header.vo# -- Compiling module test_header# -- Compiling module adc_dclk_pll# -- Compiling module adc_dclk_pll_0002# -- Compiling module altera_pll_1# ** Error: test_header.vo(17386): 'gnd' already declared in this scope.# -- Compiling module altera_cyclonev_pll_1# -- Compiling module altera_cyclonev_pll_base# -- Compiling module altera_pll_dps_lcell_comb_1# -- Compiling module altera_pll_dps_lcell_comb_2# -- Compiling module altera_pll_dps_lcell_comb_3# -- Compiling module altera_pll_dps_lcell_comb_4# -- Compiling module altera_pll_dps_lcell_comb_5# -- Compiling module f_clk_pll# -- Compiling module f_clk_pll_0002# -- Compiling module altera_pll_2# -- Compiling module spi_wr_24b# -- Compiling module rom_init_spi# -- Compiling module altsyncram_1# -- Compiling module altsyncram_obg1# End time: 10:30:12 on Sep 26,2016, Elapsed time: 0:00:00# Errors: 1, Warnings: 0# ** Error: D:/Altera/Prime_16/modelsim_ase/win32aloem/vlog failed.# Error in macro ./test_header_run_msim_gate_verilog.do line 8# D:/Altera/Prime_16/modelsim_ase/win32aloem/vlog failed.# while executing# "vlog -vlog01compat -work work +incdir+. {test_header.vo}"No RepliesBe the first to reply
