Modelsim can't find library
Thanks for the answer.
I can see the LPM library. I can't see inside the LPM library the lpm_mult_1910.
also, the Modelsim can't find lpm_mult_1910 library.
The above library is just an exmple. I see more libraries that modelsim can't find (only at Quartus 19.x and Stratix 10)
Can you help?
I not sure if using Modelsim Starter Edition could be the reason that you can't find the other library.
Could you try to install Modelsim - Intel FPGA Edition instead and try again?
- motico6 years ago
Hi
The Modelsim that I am using is Modelsim - Intel FPGA Starter Edition 10.6.
I think that you are right and the problem is not the Modelsim vertion. I am using the same Modelsim to run simulation on Cyclone without any problem.
I can guess that the Startix simulation library is not built in the same method as other FPGAs.
Help with this topic is welcome.
- RichardT_altera6 years ago
Do you able to solve your issue? Do you need further help on this?
Shyan Yew
- motico6 years ago
Hi Shyan
I still have not found solution for my question.
