Modelsim can't find library
LPM library along with other libraries are located in subdirectories of the \ quartus\libraries\vhdl directory.
Thanks for the answer.
I can see the LPM library. I can't see inside the LPM library the lpm_mult_1910.
also, the Modelsim can't find lpm_mult_1910 library.
The above library is just an exmple. I see more libraries that modelsim can't find (only at Quartus 19.x and Stratix 10)
Can you help?
- RichardT_altera6 years ago
I not sure if using Modelsim Starter Edition could be the reason that you can't find the other library.
Could you try to install Modelsim - Intel FPGA Edition instead and try again?
- motico6 years ago
Hi
The Modelsim that I am using is Modelsim - Intel FPGA Starter Edition 10.6.
I think that you are right and the problem is not the Modelsim vertion. I am using the same Modelsim to run simulation on Cyclone without any problem.
I can guess that the Startix simulation library is not built in the same method as other FPGAs.
Help with this topic is welcome.
Do you able to solve your issue? Do you need further help on this?
Shyan Yew
