15 years agomodel a buffer in VHDL
Hi, Im trying to model a buffer in VHDL but am unable to do so. I have signal A and B. I want the first signal A is loaded into a register after 2 seconds. Then, the signal B is generated ...
15 years ago --- Quote Start --- what do you mean by buffer? You need to elaborate more. Buffer is used according to several contexts. 1) I know digitally minded folks use buffer to mean storing incoming streams and then releasing it under control. This could be a block of ram or fifo or even a pipe of registers. --- Quote End --- dear kaz, mind to elaborate this function? tqvm in advace...
