15 years agomodel a buffer in VHDL
Hi, Im trying to model a buffer in VHDL but am unable to do so. I have signal A and B. I want the first signal A is loaded into a register after 2 seconds. Then, the signal B is generated ...
15 years agoThis is my code;
LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY haar IS PORT ( clock : IN bit; -- Inputs in1 : IN integer RANGE -127 TO 127; --Outputs out1 : OUT integer RANGE -127 TO 127 ); END haar; ARCHITECTURE haar OF haar IS COMPONENT bufgs PORT ( i : IN bit; clk : IN bit; o : OUT bit ); END COMPONENT; COMPONENT reg PORT ( input : IN integer RANGE -127 TO 127; clk : IN bit; output : OUT integer RANGE -127 TO 127 ); END COMPONENT; BEGIN xbufgs : bufgs PORT MAP ( clock, clk); -------Input to Register ------- r1: reg PORT MAP ( in1, clk, out1 ); END haar; I use components of register and buffer in the code. But, this error occurred when i compile this code: Error (10482): VHDL error at haar.vhd(35): object "clk" is used but not declared. Can you help me why this error is occurred.Thanks
