13 years ago
mod - remainder confiusion
Dear all,
Anyone can explain what mean by this line of code:
ad<=(-5) mod 8;
I know the "mod" is the remainder. But, why need negative? What the different with ad<=5 mod 8? Thanks in advance
    --- Quote Start ---
    Do some simple maths...
    If you divide 13 by 8 you get 1 remander 5.
    If you divide 13-8 (= 5) by 8 you get 0 remainder 5.
    If you divide 13-8*2 (= -3) by 8 you get -1 remainder 5 (or 0 remainder -3).
    If you divide 13-8*3 (= -11) by 8 you get -2 remainder 5 (or -1 remainder -3).
    Which of the quotient and remainder is negative varies according to the definition used by the language.
    --- Quote End ---
    Hai all,
    Actually I try to understand this code example. I used this code as my reference to rewrite my own code later. One more thing, I try to view the state machine diagram using Quartus, but it said that "no state machine". I search from this forum, it said that I need to add reset case to create the state machine automatically. How to add the reset case? Thanks for quick reply
    While I am not sure if this is the helpful or not (as I can not see the context of your code):
    5 as a byte:
    0b00000101
    -5 as a byte (one's complement):
    0b11111010
    -5 as a byte (two's complement):
    0b11111011
