14 years agoMinimum pulse width violation
Hey guys, I'm using the timequest analyzer. I first setup the clock using the wizard. 120Mhz. I'm using Cyclone II, C6. After performing compilation and checkin...
14 years agoThanks for the help ashishkaps. If the clock frequency is acceptable, then what could be causing this problem?
I can't avoid the latches. The altsyncram memory is synchronous. Every input to the module is latched with the clock. It seems that the error is occuring with that component.
