Migrating design from MAXPLUS to Quartus
Hi Naveen,
You may refer to link below for details how to get access scf and snf file using Maxplus. You can try to open it using Waveform Editor in Quartus as it same thing which is functional tool as in Maxplus, let me know if works. Since you can migrate to bdf, you can straight away simulate your design in QP using Waveform Editor which later produce vho/vo netlist of your design.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/_81_gs2.pdf
- NShan126 years ago
Hello @SyafieqS
Thank you for the link.
The waveform editor can open only .vwf files and not .scf or .snf files. I tried this in both Q13.1 and QP18.1. Hence I still need to find out how to access the content in .scf and .snf files in Q13.1 or in QP.
Also, any idea how to use a .vec file to drive simulation inputs? I have a large vector file which has simulation test vectors. I would like to use this to drive the input signals during simulation.
