15 years agomegawizard plug in manager confustion.
is there a megawizard tutorial or something? I am trying to use a picture that I converted from the altera program imgconv.exe from a text file to a mif file and just confused about the code.
I am trying to use the altera program imgconv.exe along with the megawizard plugin function to intialize the sram so that I can modify it. If someone could point me in the right direction I would appreciate it.1 Reply
I am sure there are guides on altera site. However, using this tool is the only case - I admit- of being truely easy and user friendly. Just follow the prompts.
you instantiate your ram/rom then once you arrive at mif selection just navigate to it. if your mif is incompatible with your ram/rom selection then you need to match sizes.
