18 years agoMegawizard FIFO problem: Write and read request filling FIFO!
Hi, Well this has to be the most bizarre problem I've ever encountered. I've found that the read request signal to the fifo occasionally results in the fifo used counter to be incremented and t...
18 years agoDo you have the chance to let this run with other frequencies ? other fre-relations? Could you figure out a time pattern of the corrupted data ? Which device is it ?
