18 years agoMegafunction altparallel_flash_loader--what is this
Hi All The flash loader in the megawizard, for the cyclone III will that let me write and read bytes the the Flash. If so is there any information in its setting etc. I have been strugglin...
18 years agoThanks very much, ychen.
In my work , I want to use two data sheets , which are two related sheets, one is displacement, the other is related PWM signal that will drive other circuits. I have to give FPGA the the two 16bits-width-data at the same time. I don't know any better ways to give FPGA 32 bits-width data except accessing both flash. I will be very grateful to you If you could advise me some better ways. I tried to use two Tri-state bridge and two CFI in the sopc design, and link the first Tri-state bridge to CFI0, the second one to CFI 1, then I generate the sopc.bdf. It seems like it can work. Shown as the pic I attached.
