18 years agoMegafunction altparallel_flash_loader--what is this
Hi All The flash loader in the megawizard, for the cyclone III will that let me write and read bytes the the Flash. If so is there any information in its setting etc. I have been strugglin...
18 years agoHapyang,
From what I can tell, your data sheet does not contain address info; the address info is provided by UltraEdit as it displays the contend of your binary file. If you are building an independent system, you would need add a JTAG UART, Nios II, and a Common Flash Interface Controller core to your SOPC builder. Write some code for Nios to read from the JTAG UART and write to the Flash controller. You will need to decide the starting address you want to write in the flash and increment the address as you write. Having said the above, Altera has already included a Nios II Flash Programmer which does this. (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf) Instead of using a JTAG UART and writing your own code, Nios II Flash Programmer transfer the data via Nios' JTAG debug port. Hope this helps.
