18 years agoMegafunction altparallel_flash_loader--what is this
Hi All The flash loader in the megawizard, for the cyclone III will that let me write and read bytes the the Flash. If so is there any information in its setting etc. I have been strugglin...
18 years agoThe data sheet I use is 512K , which contains address and data as the picture I attached.
The data sheet was made with VC++, the format boss gave to me is " .DAT" , you can open it in UltraEdit. I plan to use jtag to download the data sheet into FPGA , then the FPGA write the data into the flash. Problem is I don't know whether the Flash Programmer of Nios IDE can get it. The data written into the Flash will be read by FPGA , meanwhile FPGA works. I had used MCU to write W29C040 and DS1250Y-70. It is the first time I use Nios , the materials I get from altera is just using Flash to configure the FPGA but not to store data as I said. That is my trouble bothering me for a long time. Look forward to your reply! Thanks very much.
