10 years agoMe and my simple questions: Can I do this in FPGA?
Hi dear Altera friends. Sorry for the simple questions, i'm a beginner. My FPGA is DE1-SoC University, i'm learning how to use it. My question today is the following one: Until now, with t...
10 years ago --- Quote Start --- # ** Error: C:/Users/..../Downloads/altera/fixed_pkg_c.vhdl(22): Library ieee_proposed not found. # ** Error: C:/Users/..../Downloads/altera/fixed_pkg_c.vhdl(23): (vcom-1136) Unknown identifier "IEEE_PROPOSED". # # ** Error: C:/Users/..../Downloads/altera/fixed_pkg_c.vhdl(25): VHDL Compiler exiting Model Sim doesn't like the VHDL 2008? Quartus II seems to compile, but when I try to use modelsim for simulating it gives me this error. --- Quote End --- This is because you didnt create the ieee_proposed library in modelsim. Quartus is quite relaxed when it comes to libraries unless you specify them - it just searches all design units for the correct packages. as you might have guessed, ieee_proposed was just a placeholder name for the code before it was officially released, and still holds for the '93 compatible code. You can modify it if you wish to be ieee or work. But modelsim already has the fixed_point libraries (in 2008 format) in the ieee library. as for your code, resultado needs to be declared: resultado : out ufixed (3 downto -7); Otherwise you miss the carry bit (numbers never get smaller when added).
