15 years agoMay I use max-ii device in this way(Power related problem)
1. Power for VCCINT and some bank are applied at first while other bank has no power. Power for other bank are applied at a later time? 2. Apply different VCCIO voltage as the voltage specified in...
15 years agoI don't understand what you want to achieve with assigning a different IO-voltage. The assigned voltage has no meaning but relating different mA numbers to low and high current strength. It has no impact on the configuration programmed to the device. Low and high current strength is the only possible variation for MAX II.
