13 years agoMaxV IO voltage compatibility
Hi everyone, I am working on a MaxV design that needs IO compatibility with ICs that will be powered from 2.3V. Looking at the MaxV datasheet and the pin configurations in Quartus I am led to ...
13 years agoThanks for the reply. Do you have any insight as to what is different in the chip when the different voltages are selected? I read somewhere on one of these forums that the voltage selection had no effect on how the device was programmed and that the voltage setting was used by Quartus for calculations of power consumption, etc.
