13 years agoMAX+PLUS II project not compiling in Quartus II 7.2---
Hai, i have MAX+PLUS II project file, which is successfully executed in MAX+PLusII, but RTL netlist viewer is not possible to open in MAX+PLUS II, so i converted this project into quartus II proje...
13 years ago --- Quote Start --- usually you can just compile the files without problem. I have this thought in the back of my mind that M+P2 has really terrible VHDL support so probably allows some stuff that would be illegal in normal VHDL, and the same with AHDL. What are the errors and can you post them? --- Quote End --- i got errors like this : VHDL syntax error at x.tdf near text "FUNCTION"; expecting "entity", or "architecture", or "use", or"library", or "package", or " configuration" like this so many VHDL syntax errors are coming
