11 years agoMax/min current to a GPIO
Sorry, this is a very well documented question through the manual, but I was hoping to clarify some things: What I want to do is connect 16 detector response to a DE2-115 to get the signals in ...
11 years ago --- Quote Start --- Please post a schematic/drawing of your proposed interface. --- Quote End --- hi. apologies, i should have added the schematic before. NPN transistor: NXP BDT125. Max I_c is 6.5mA. Its switching is 2Ghz so it should not give much delay. I will probably add a speed-up capacitor if i need more performance. X1-40 goes to the GPIO. My plan: RB_0=93.5kohm. RE_0=3.3 kohm GND is connected to the GND pin of the ATA header and and the V_cc to the 3.3 V pin I_b comes out to be 0.019 mA. And I_c, comes out to be 0.75 mA. I can probably change the resistors and and the V_cc to 5V and get I_c to be 3.3 mA, but I rather not if I can get away with it. my concern was if the GPIO will be sensitive enough to react to the change in voltage at 50ns. cheers. PS: i did some additional googling, and I came up with this pdf which states the JEDEC Standard No. 8-5A.01 using by the GPIO and the file has an Absolute maximum continuous rating of as +/- 20 mA. the file also specifies normal operating conditions where It says I_i (Input current) for both high and low as +/-15micro amp. This is all good. however, if that is specification of JEDEC Standard No. 8-5A.01,, i was hoping someone to confirm that this would work with 0.75mA "source strength". I would hate to make a PCB board only to blow up all the transistors :(
