10 years agomaximum IOs per bank
Hi Community,
referred to the m10_sidg.pdf p.7 table 2. I will use a deserializer (MAX9276) and the outputs of this IC are using the LVCMOS standard. I looked up the DS of the IC with the electrical characteristics and under my given input signals (RX TX), there is an output current of 3mA. Does this mean I can only use 65% of each bank, because it is not recommended to use more than 65% of each bank using the I/O Standard? Regards JérômeNo RepliesBe the first to reply
